Help Load Fan
Solved by GhostRoadieBL,
46 minutes ago, CoolName80 said:
I have two / three total fans in my case one rear, one on cpu , and one on gpu.
Replacing the rear and cpu fans and I think you can have one or two at the front for intakes.
Cpu fan will make the most difference in noise but an exhaust and intake will be good for overall lower temps so less noise
