2 hours ago, Ero said:
Rx 5600 xt have lower power consumption than rx 580 but your current gpu is not that bad, I recommend waiting for next gen gpu to launch. 60 and 50 class cards should be in market at near Christmas and have good stock as well.
Ive decided to switch coz may rx580 broke. I need a replacement asap
https://linustechtips.com/topic/1258616-power-supply/#findComment-14125051
16 hours ago, awnicho said:
Even if its not a tier A or B list PSU? Is it safe?
Though you said that your power supply is 80+ rated, after looking for your PSU online, it seems like a very cheap and unreliable one. I am not saying that it is not capable of running what you are wanting to use; I am just saying that I would buy a new one if I were in your situation. In my opinion, I would spend an extra 100$ for an EVGA or Corsair PSU. In the end, you may end up saving more money. :)
Here are links to some good ones.
https://www.newegg.com/corsair-rmx-series-rm750x-cp-9020179-na-750w/p/N82E16817139233?Description=corsair powersupply&cm_re=corsair_powersupply-_-17-139-233-_-Product&quicklink=true
https://www.newegg.com/evga-supernova-750-g3-220-g3-0750-x1-750w/p/N82E16817438093
https://linustechtips.com/topic/1258616-power-supply/#findComment-14127152
