I'm thinking of doing a custom loop and im wondering how much it will cost USD.
Needs/Info:
I have a NZXT phantom so what ever size rad i would need/where  could i put the rad.
Cpu cooling
1 GPU/ 2 later.
red or white fluid.
i really like the look of the acrlyic hard tubes if they arent to much harder to do.
T-virus Res
where do i buy all this stuff?
I think that is it.
how much (roughly) will this cost?
also i have a 1200W PSU is that enough with sli?
thanks i will add anything if i think of it hope this is doable.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/12586-custom-loop-help/
Visit www.aquatuning.com it will be VERY expensive if you want all that stuff. Estimated ~ 700$. 1200W are enough for two Mars IIs, so don't worry
what about cutting out the acrilyc?
https://linustechtips.com/topic/12586-custom-loop-help/#findComment-134067
For the US, go to frozencpu.com or performance-pcs.com - they have excellent selection. For your first build DO NOT use acrylic tubing, otherwise known as crystal link, for anything other then say the pre-cut for an sli/xfire bridge. It is a very difficult material to properly work with, cuts have to be perfect and prone to leaks. Stick with tubing and make your runs neat and tidy.
Initial costs on a good quality custom loop? Can very. Frozencpu have some nice starter kits, 360mm rad - in about $350... if you are looking to add GPU, t-virus, etc, of course costs go up. PLan on $500 to start. My first build with dual rad, xfire setup came in around $700.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/12586-custom-loop-help/#findComment-134203
