Build for Work
Go to solution Solved by Abdullah Bhutta,
This is the best according to your budget
please find these things your self:
DP to HDMI cable 6 ft for displays
Ethernet cable 10 ft
ASUS internal CD drive
Budget (including currency): Idk, 2500 USD tops
Country:  United States
Games, programs or workloads that it will be used for: Mainly Number Crunching and doing work on large datasets.
Hi all, I'm back in Education IT. I have a new professor coming in who's going to be doing a lot of coding and working with large datasets for his research. Below is the build he would like me to make/ obtain. Does anyone else find this like maybe a little weird for the use case? And if so, what would you recommend different? It's been a little while since I have built a computer, but isn't AMD like top dog on working on large workloads right now? I know he's going to be using a crap ton of MatLab if that matters
Motherboard-ASUS Z490-P
Processor-Intel i7 10700K 8/16 core 3.8/5.1 GHz
RAM-Patriot 2x16GB DDR4 3200 MHz
HDD-Seagate Barracuda 2TB 7200 RPM
PSU-Corsair 650W
GPU-Nvidia GTX 1650 4GB GDDR6
Keyboard/Mouse-Logitech MK345
Monitor-Acer 24 inch 1080p
CPU liquid cooler
Case-Cougar MX330
Fans-120 mm (3 pack)
SSD-Samsung 860 EVO 1TB M.2
https://linustechtips.com/topic/1258350-build-for-work/
https://linustechtips.com/topic/1258350-build-for-work/#findComment-14122687
I would go for a Arctic liquid freezer II 280mm AIO. Better performance and silence. Also no RGB, unless you want that. And if you want something a little more compact, get a fractal design r7 compact. And do you really use a CD drive in 2020?
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1258350-build-for-work/#findComment-14122881
12 hours ago, Abdullah Bhutta said:
He needs it for his professor(professors are almost 70-80 years old)
Alright, then I still recommend the other case and cooler.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1258350-build-for-work/#findComment-14125335
