Hey guys I am looking to put together a NAS and want to use free NAS as my OS. I have a old dell that needs a new power supply and bigger hard drives to hold my data. Do you guys think an old Athlon 64 X2 with 1g of ram will be ok or should I by a new hardware, or a premade one? All I want this to do is exist as a Plex server.
https://linustechtips.com/topic/125829-nas-help/
1gb of ram with freenas is a no-go. FreeNas demands at least 4gb on the super low end. And an aditional 1gb of ram for every TB of disk space you add.
Edit: the processor should be fine though.
CPU: i7 3770k @ 4.8Ghz Motherboard: Sabertooth Z77 RAM: 16GB Corsair Vengeance GPU: GTX 780 Case: Corsair 540 Air Storage: 2x Intel 520 SSD Raid 0 PSU: Corsair AX850 Display(s): 1x 27" Samsung Monitor 3x 24" Asus Monitors Cooling: Swifttech H220 Keyboard: Logitech 710+ Mouse: Logitech G500 Headphones: Sennheiser HD 558 --- Internet: http://linustechtips.com/main/uploads/gallery/album_1107/gallery_12431_1107_23677.png My Setup:  http://linustechtips.com/main/gallery/image/7922-1-rkcf7io/ -- NAS: 3x WD Red 3TB Drives (RAIDZ-1), 5x 750gb Seagate ES HDD(RAIDZ-1), 120gb SSD for caching, OS: FreeNAS --  Server 1: Xeon E3 1275v2, 32GB of RAM, OS: ESXi 5.5 -- Server 2: Xeon E3 1220v2, 32GB of RAM, OS: ESXi 5.5
https://linustechtips.com/topic/125829-nas-help/#findComment-1672830
Linux in general will happily run on such a system and it should be able to max out a 1 gbit/s network on sustained transfers at least. You will want to avoid RAM heavy filesystems such as ZFS but otherwise a basic RAID setup and ext will perform adequately and on the lower RAM amount.
https://linustechtips.com/topic/125829-nas-help/#findComment-1672862
Would the processor be ok with the 4gb?
How much storage do you want to put in it? 4gb is still pretty low.
https://linustechtips.com/topic/125829-nas-help/#findComment-1672895
I was think 3TB
Ok, 4gb would be the minimum i would go with, but remember with freenas the more ram the happier freenas will be.
https://linustechtips.com/topic/125829-nas-help/#findComment-1672973
I use nas4free with 512mb ram, It handles veeam backups quite well and I have never had any issues with it.
Break it. Put it back together.Then hope like hell it works. Failing that Use Gaffer Tape.... lots of it. If that doesn't work then either there isn't a problem or you haven't used enough gaffer tape,
https://linustechtips.com/topic/125829-nas-help/#findComment-1673411
Do you use the ZFS file system? And how much hdd space do you have?
https://linustechtips.com/topic/125829-nas-help/#findComment-1673441
