7 minutes ago, Butterz1999 said:
Does anyone know if Inland Platinum 2TB SSD 3D QLC NAND M.2 2280 PCIe NVMe 3.0 x4 M.2 Internal Solid State Drive is compatible with b550 boards?
Plz send help
Yes it is. It just goes into your m.2 connector, just make sure the board you want has PCIe m.2
lttstore.com
https://linustechtips.com/topic/1258238-i-need-help/#findComment-14121424
Plz send help
yes, the m.2 is a very nice conector because its conpatible with bisically every M.2 thing (there are some veriants of m.2 connectors but for the last  3-4 years all m.2 are universal with all the m.2 veriants)
https://linustechtips.com/topic/1258238-i-need-help/#findComment-14121483
