i would guess that it would be the same unless they have different sensors
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/125806-dpi-question/#findComment-1672403
Thanks that is what I was looking for!
However I would not recommend using 900dpi. I use multiples of 400 so that I know for certain almost every mouse supports the dpi I want. If you for whatever reason switch mice you might not be able to do 900.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/125806-dpi-question/#findComment-1672480
One of the main reasons I like adjustable mice is that you can fine tune the DPI.
If he likes 900, it's not hard to find another mouse that supports it.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/125806-dpi-question/#findComment-1672495
