Specs
mother board:MSI Performance Gaming AMD Ryzen 2ND and 3rd Gen AM4 M.2 USB 3 DDR4 DVI HDMI Crossfire ATX Motherboard (B450 GAMING PLUS Max)
cpu:AMD Ryzen 5 3600 6-Core, 12-Thread Unlocked Desktop Processor with Wraith Stealth Cooler
Psu:Apevia ATX-PR800W Prestige 800W 80+ Gold Certified, RoHS Compliance, Active PFC ATX Gaming Power Supply
gpu:ASUS AMD Radeon RX 5500XT Overclocked O8G GDDR6 Dual Fan EVO Edition HDMI DisplayPort Gaming Graphics Card (DUAL-RX5500XT-O8G-EVO
Storage:Western Digital 1TB WD Blue SN550 NVMe Internal SSD - Gen3 x4 PCIe 8Gb/s, M.2 2280, 3D NAND, Up to 2,400 MB/s - WDS100T2B0C
if you guys have a better pc setup for $1,500 US dollars
https://linustechtips.com/topic/1258044-first-pc/#findComment-14119260
Ram:CORSAIR VENGEANCE RGB PRO 16GB (2x8GB) DDR4 3600MHz C18 LED Desktop Memory - Black
case:MUSETEX Phantom Black ATX Mid-Tower Case with USB 3.0 and 6 ×120mm RGB Fans, Tempered Glass Panels Gaming PC Case Computer Chassis(907)
this goes wit the last post
https://linustechtips.com/topic/1258044-first-pc/#findComment-14119282
5 minutes ago, Lord Vile said:
Right this is how much that would cost to build, i wouldn't trust that PSU it seems too cheap and the motherboard costs like the same as a good X570 board.
And this is a build without a GPU but with 600 left for a GPU. Not putting one in because buying a GPU new now is dumb, the new gen of cards are all sold out and the last gen are still at MSRP so I would either look for used cards for under MSRP or wait for the new gen cards like the 3070 (Not released yet but will sell out in 5 seconds) and 3080 to come into stock. To put it into perspective I've just bought a 1080Ti for £320 used which outperforms/ is on par with a 2070 Super which currently sells for £500 minimum for a low end model. You just don't get stuff like ray tracing and DLSS with the 1080Ti.
I already have the case and psu
https://linustechtips.com/topic/1258044-first-pc/#findComment-14119364
20 minutes ago, Lord Vile said:
Why did you pick an 800W PSU that's half the price of any of the decent 650W ones and a case that looks horrendous to build in? XD
Should have asked before you bought stuff really. Though the rest of the builds still remain largely the same.
The case doesn’t look to bad
https://linustechtips.com/topic/1258044-first-pc/#findComment-14119433
2 hours ago, Linus rulz said:
Help with first pc
we really need more info, like many before me already posted.
we need:
general usecase for PC (gaming, work, editing etc)
budget and currency
just the PC or full setup?
preferences? do you want a big PC or a small formfactor one.
https://linustechtips.com/topic/1258044-first-pc/#findComment-14119793
15 minutes ago, RollinLower said:
that would honestly be the very first one i've ever recieved on this forum.
OT:
we need:
budget and currency
gamming and streaming
buget 1,500 us dollars
just pc
big pc
https://linustechtips.com/topic/1258044-first-pc/#findComment-14119861
just pc
big pc
do you want it right now or are you comfortable waiting untill the 3000 series from nvidia becomes widely available?
https://linustechtips.com/topic/1258044-first-pc/#findComment-14119934
-Cleaned-
-Moved to New Builds and Planning-
OP When you post, make sure you add details. We literally cannot do anything with "help".
https://linustechtips.com/topic/1258044-first-pc/#findComment-14120167
