Choosing an air cooler
jdkm101
HI all,
Built a new pc and looking at air coolers but having trouble deciding on what to get as im not 100% sure on clearance due to the ram size.
Motherboard asus strix gaming F (non wifi)
ram - vengence RGB Pro
CPU - 3600x
been looking at noctua or be quite but any any options are welcomed
budget?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
i think nhd-15 or dark rock pro 4
one question, this motheboard is good? i am looking to buy a new mobo.
Just now, HelpfulTechWizard said:
budget?
anything up to £100 will be fine rather not spend more than that on air cooling, its only a 3600x i cant imagine it getting to hot
would there be enough clearnace on the ram vengence pro sits quite high.
Had it a couple of weeks now no issues whats so
yes, its a nice mobo.
The dark rock pro 4 from bequiet will need the fan raised, but it dhould work. its about 89USD, so it souulb be less than 100 GBP
Bios database
prior build:
And the Dark Rock 4 Pro is better than the NH-D15 in that aspect because the front fan is smaller if I recall correctly. I had to swap the front fan of my NH-D15 because of ram clearence issues (raising the fan made it go physically outside the case). For a 3600x you can get away with something way smaller. If you don't mind spending the money and the brown color scheme the NH-U12a is the best option IMO and you won't be constrained by RAM clearence issues.
Ada is worse than Ampere which is worse than Fermi, change my mind.
System:
  • CPU
    AMD Ryzen 9 5950x
  • Motherboard
    ASUS X570 TUF
  • RAM
    2X16GB Kingston Fury 3200mhz
  • GPU
    Gigabyte RTX 4080 Super Gaming OC
  • Case
    Fractal Torrent
  • Storage
    A lot of SSDs
  • PSU
    Seasonic 1000W Platinum
  • Display(s)
    Main: ASUS PG27AQDM 240hz 1440p WOLED
    Secondary: Alienware AW2521HF 1080p 240hz
    Third: Samsung C34F791 UltraWide 1440p 100hz
    Fourth: LG 48' C2 OLED TV
  • Cooling
    Noctua NH-D15
  • Keyboard
    Ducky Shine 7
  • Mouse
    GPX Superlight
  • Sound
    Logitech Z906 / Sennheiser 560s / Rode NT-USB
  • Operating System
    Windows 11 Pro
I have an NH-U12a and it is great with my r5 3600. Underload my temps don't go above 50c. I would recommend It.
Cheers for the help guys👍  will give the dark rock pro and the NH-U12 a look
What case are you using? What kind of features are you looking for in a cooler?
case is the meshify C, PC is only used for light gaming and work so just need to keep the temps low is, going with air cooling as the pc is on the desk and pump noise was annoying me from my last build
The 3600x isn't difficult to cool.
Mugen 5 Rev. B and Fuma 2 are good options for low noise and completely clear the ram slots.
https://uk.pcpartpicker.com/product/8GBrxr/scythe-mugen-5-rev-b-5117-cfm-cpu-cooler-scmg-5100
https://uk.pcpartpicker.com/product/YsHRsY/scythe-fuma-2-5117-cfm-cpu-cooler-scfm-2000
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
