I bought the Asus TUF H3 headphones 1 month ago and I didn't drop them or hit them in any way.
3-4 Days ago I started hearing the audio only from the left ear and when I bend them a little it fixes it self.
It's not the software like the mono audio or something it's the headphones.
Can I do something or I have to open them?
https://linustechtips.com/topic/1257335-headphone-problem/
12 hours ago, rice guru said:
best thing to do is contact asus and get iot replaced its only a month old so warranty should cover it.
Well my country is not like usa or those bigger ones. In my country if you brake it, They can't fix it for you, it's only if you get them broken out of the box.
https://linustechtips.com/topic/1257335-headphone-problem/#findComment-14115847
