Hi recently i have tried to fix my low GPU and CPU usages in games as most of the time my CPU and GPU doesn't exceed 50% and i get it in pretty much all games other than warzone for some reason specs (ryzern 5 1600, 1660 super, 16gb ram one 2400 and other 3000 and overclocked to 2933mhz ssd etc) but by doing so i have made the situation worse as now when i look around in games my GPU decides to decrease a lot to the point where im on like 10fps and the usage goes as low as 10%
i have tried everything such as reverting what i did to try and fix it, clear bios so no ram overclocks etc but nothing is working maybe there was something i did but cant remember what.
I updated bios GPU and chipset drivers so maybe it was that but  would have no clue how to revert
also i play games such as minecraft where i go as low as 15fps, warzone and rust theses are the games i have been playing recently
Any help would be appreciated thanks!
https://linustechtips.com/topic/1257269-gpu-help/
I concur with @Nick Neuburg.  Temperatures should be checked.  If you’ve got thermal problems it could explain your issue.
https://linustechtips.com/topic/1257269-gpu-help/#findComment-14113353
