So today i bought a second hand computer, it started and all till i took out things to clean graphics card etc, it ran just fine. i took out the heat sync and graphics card, when i took out the heatsync the processor came out aswell. i plugged everything back when i was done (correctly) now it boots but dosnt show a screen on my monitor. please help
https://linustechtips.com/topic/1257238-need-help-please/
Do you get any display output at all (like pre-boot sequence screen)? Otherwise you could try to use a different port on your GPU. Also try to trigger manual input search on your monitor after starting up. I have a monitor that likes to get stuck on a not connected input and doesn't recover from that until I specifically tell it to look for new connections xD.
https://linustechtips.com/topic/1257238-need-help-please/#findComment-14112969
