21 minutes ago, im a noob at pc said:
Can someone help me i have a pc that doesn't turn on but the fans are running but the monitor is plug in and everything
Does the cpu fan turn on? or ther's just no video output?
Remember! Reality Is An Illusion, The Universe Is A Hologram, Buy GOLD! Byeeee!!!
https://linustechtips.com/topic/1257086-pc-problem/#findComment-14111727
Please list your components so we can check if it is able to work.
In general, unplug and replug every single connection to make sure cables are plugged in correctly.
If you have a graphics card, insert the monitor cable into the graphics card - not into the motherboard.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1257086-pc-problem/#findComment-14111785
5 minutes ago, im a noob at pc said:
theres just no video output but the cpu fan id running
If the PC just stays on and not resetting or turning on and off by itself (boot loop) it could be either the RAM or GPU
Try these steps
1. Reseat the RAM then try to boot it up again
2. Reseat the GPU then try to boot it
If both of those steps doesn't work the try step 3
3. Reseat the CPU
Try doing this one at a time to eliminate any variable. Almost forgot every time you try to boot mash the delete button
https://linustechtips.com/topic/1257086-pc-problem/#findComment-14111969
