On 12/23/2019 at 6:58 AM, brenzo said:
So basically just built a new pc
specs
1660ti
ryzen 5 3600
240 gb ssd
3200 mhz ram
650 watt Corsair 80+ bronze
b450m pro ASRock motherboard
mouse model o-
basically after playing for some time my mouse randomly starts having input lag. I play fortnite and my mouse movement feels delayed. The weird thing is one restart and my input lag is gone. I restart my pc and it’s completely normal. The temperatures are fine I’m not sure what it could be. any ideas?
Hello bro i am having the same issue as you have, when i restart my mouse goes to normal.
i have the same build as you but different power supply and motherboard.
i am tired of this issue so if you found the solution plz reply back to me asap.
Thanks,
https://linustechtips.com/topic/1257044-mouse-input-lag/
*** Thread split from another ***
Original
Please don't necro/hijack others threads. You having different motherboard is enough to make issue completely another.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1257044-mouse-input-lag/#findComment-14111448
