Hey Guys,
So im going to water cool my computer and i need help on what parts i should get and stuff. Im not sure as i havent water cooled before. I live in Australia so please link me Aussie stores only.
I want a pump/reservoir combo which can slip into a two slot drive bay as it'll be easier to access along with all the other screws and stuff. im clueless like a penguin in a desert.... I want to it match the rest of my build which is blue. I want to water cool my cpu and gpu. No need for fans.
My budget would be about $400-$459 aud
My Build: http://pcpartpicker.com/p/37jZq
CPU: i5 4670k @ 3.4 Ghz MOBO: Asus Z87 Sabertooth RAM: Corsair Vengeance 2 x 4gb @ 1866Mhz GPU: GTX 780 Ti Case: Corsair 750D HDD: Kingston 120gb, WD 500GB & WD 1tb PSU: Corsair Rm 750w with Blue Sleeved Cables Monitors: Acer 24", Acer 21", Samsung 18" CPU Cooling: Cooler Master Seidon 120M Keyboard: Roccat Ryos MK Pro Mouse: Razer Death Adder Speakers: Edifer 5.1 Surround Sound Microphone: Blue Yeti
PcPartPicker: http://pcpartpicker.com/user/LozzaNewport/saved/4dT0
https://linustechtips.com/topic/125704-custom-water-loop/
The XSPC Dual Bay Reservoir was the only one pump/reservoir combo I could find on PCCG :
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_299&products_id=14352  <--- Does not include a pump, but can support a pump.
You can stick some blue LED's in there for colour matching.
Have fun building your loop!
EDIT: Found two more. One is dual pump, and the other is single:
Dual: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_296&products_id=21256
Single: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_296&products_id=21957
Sorry for the convoluted speech pattern.
https://linustechtips.com/topic/125704-custom-water-loop/#findComment-1670965
How much space for rads do you have? What case are you using?
New PC Build - Build Log - http://linustechtips.com/main/topic/276039-project-swift-force/
[spoiler=]
  • Case: Phanteks Enthoo Primo
  • Motherboard: Asus Maximus VII Hero
  • CPU: Intel i7-4790K
  • GPU1: GIGABYTE G1 GAMING GTX 970 4GB
  • GPU2: GIGABYTE G1 GAMING GTX 970 4GB
  • RAM: Corsair Vengeance Pro Red, 16gb (2x8GB) @1600mhz
  • PSU: EVGA SuperNova 850W 80+ Gold
  • CPU Cooler: NZXT Kraken X61
  • HDD: Seagate Barracuda - 2TB 7200RPM
  • SSD: Samsung 840 EVO - 250GB
  • Monitor: Asus PG278Q ROG Swift 27" 144hz G-Sync
  • Headphones: Beyerdynamic DT990 Pro 600 OHM
  • DAC/AMP: Mayflower Objective2 + ODAC Combo
  • Mouse: ROCCAT Kone Pure Optical
  • Keyboard: KBP V60 - Cherry MX Brown
https://linustechtips.com/topic/125704-custom-water-loop/#findComment-1670985
in the link in the topic...i have enough room for a 360 rad at the top which i would like to put one there
https://linustechtips.com/topic/125704-custom-water-loop/#findComment-1670996
You do realize that the first link you put up does not include a pump right?
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/125704-custom-water-loop/#findComment-1671148
yea, i was reading about it
https://linustechtips.com/topic/125704-custom-water-loop/#findComment-1671179
Ok, i was just wondering.
Regarding your radiator configuration, i know you said you want a 360mm on top but i know you would get better performance by using three of these.....http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_297_922&products_id=25479 one for the top, bottom and front.
https://linustechtips.com/topic/125704-custom-water-loop/#findComment-1671290
