Hullo,
I'm looking for some help selecting parts for a desk audio setup. I have a budget of $800 USD (Soft limit) to $1100 (Hard limit). I don't particularly care if the speakers are powered or not, but It would save some hassle. I'm looking for at least a 2.1 setup, and am Impartial to surround sound- Whatever you think will be the best expereince, I'll go with. The budget is for all needed components, including speaker stands, amps/dacs or ac receivers, ect. For the color scheme, I'd prefer something like what klipsch does- Copper and black, but I don't particularly care about the color, as long as the colors are mostly neutral (Black, grey, white, ect.)  Here's a draft of what I'm thinking for some possible setups:
2.1
-Klipsch The fives powered speakers (pair) ($800)/Audioengine A5+ (~$500)
-Klipsch Sub-100, or similar sub ($200-$300), May go with more expensive sub?
-Cables: (>$50)
4.1:
-Klipsch RM-41(P)M (2 pairs [Costco has the M's on sale for $89.99/pair, and I can pick up PM's for as low as $250/pair, but I think I'll need a receiver, so I'll probably go m's) ($180-$500)
(Alt option: Two RM41m's, two towers)
-5.1/2 or 7.1/2 receiver ($300-$600) Is 2khz a good idea or it fine to go with 1?
-Stands: ($100) (maybe less, I need two if I wanted to go true surround with two in the back, but I could also just have a front radius)
-Cables (~$50)
5.1:
-Klipsch RM-41M ($180)
-Klipsch 250c or related center channel ($150-$250)
-5.1/2 or 7.1/2 receiver ($300-$500)
-Stands: ($100 or so)
-Cables:(~$75)
Thoughts? Recommendations?
If you need any more information, please ask for what you need, I'll get back to you.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1257022-need-audio-help/
Imho surround is useful for movies or gaming but not really listening to just music.   I’m old though.  There may be bias.
https://linustechtips.com/topic/1257022-need-audio-help/#findComment-14111328
Alright, I'll primarily be listening to music, so maybe I won't go surround sound. Do you have any setup suggestions?
https://linustechtips.com/topic/1257022-need-audio-help/#findComment-14111350
