Fan configuration inside case
By
AndreiArgeanu
in Cases and Mods
in Cases and Mods
Solved by aisle9,
Just now, AndreiArgeanu said:I assume as an exhaust? I'm running the stock cooler that came with my ryzen 3100 and it's fine as far as I'm concerned.
Yes, exhaust. It's an even better idea given that you're using a top-flow cooler which basically barfs that air everywhere instead of just pushing it out the back.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases2 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
