I have a top mount in my case for my psu so  should I place the psu fan down where there is no fresh air or up where there is not ventilation link there is not gap to get fresh air. Which side should I go for?and will it effect the performance of the psu?
The below given image of  Power supply is not the one I have but the design is same
https://linustechtips.com/topic/1256066-is-it-normal-need-help-pc-support/
Get yourself a new case ! Such a good psu, probably also good quality components and then a shit case..
the more a pc can breath the better, right 😉
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
So can u send me a link which is a inexpensive case and my psu is not that mine is a gigabyte GP-P450B
Oh.. yeah that’s a firebrick 🤣
what system are you powering ?
Ryzen 3 3200g
Gigabyte GA-A320M-S2H
Thermaltake power supply (I changed my power supply)
Crucial 8 gb ram
And is this power supply good?https://www.amazon.in/dp/B00LEKFDSE/ref=cm_sw_r_cp_apa_fab_OgZGFb5TCSWR6
Believe it or not, there was a time (not too long ago... about 10 years ago) that ALL computer cases were like that.
If a PSU actually *needs* fresh air to operate properly, it's a shit PSU.  Most quality PSUs can operate at full load upwards of 40 to 50°C. And if your PC is THAT HOT inside, then you have bigger problems.
And I agree that the P450B is a garbage PSU.
Ya it is not that hot here it is pretty chilly weather here so I think there will be no problem. If the gigabyte one is trash should I go for the thermaltake litepower 450w?
That Thermaltake is even worse than the Gigabyte.
So no graphics card?
