sorry if wrong subforum
Lately, my GPU has been making weird noises. I investigated it, and found the 2nd GPU fan to be the culprit. Here's a photo with the fan that was making the noise.
Weeks later (today), I investigated further. Seems to be that the fan is loose, and is hitting a plastic thingy. The fan is too loose. Here's a picture, with the plastic circled. Couldn't get a better picture.
Anything I can do without spending >$35?
Edited by wall03
format
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1255575-gpu-fan-too-loose/
Are the screws loose?
There should be 3x small screws that holds the fan to the cooler.
You can tighten those screws up.
Sapphire made it so the fans can be removed by taking out the 3x screws....in case the fan dies, and you can order replacement one(s).
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1255575-gpu-fan-too-loose/#findComment-14098723
where do I look for them?
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1255575-gpu-fan-too-loose/#findComment-14098728
You already found one of them in your picture.
There should be 2x more under the fan blades, spaced out in a Y-shape.
Never mind, they are only held down by one screw.
You already found it in your picture.
They are "quick disconnect" fans.
GPU RX 580 RX 570 Cooler Sapphire NITRO Gear LED Fan For RX580 RX570 Card  Cooling|led fan|fan ledcooler fan led - AliExpress
SAPPHIRE Radeon RX 580 Nitro+ Review | TweakTown
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1255575-gpu-fan-too-loose/#findComment-14098754
