So i need a new mic setup to record some sweet youtube vids. Anyways i've been looking at the Behringer XM8500 Bundle, Millenium MA-2040 and the Shure A58WS BK. should i switch something up or is this good, is there anything i should know about these things, and should i get a pop filter as well?
https://linustechtips.com/topic/1255365-need-mic-setup-help/
You might want to check out the link in my signature, it's basically designed to answer this exact question and provide more info on the options available.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1255365-need-mic-setup-help/#findComment-14098393
