I wanna buy a budget-friendly gaming headset, and I have doubt between three models and need your help.
First one: Havit HV-H2026D - https://www.havit.hk/products/h2026d-gaming-headset/
Second one: Onikuma K9 - https://www.onikumagaming.com/products/onikuma-k9-retractable-mic-giming-headset
Third one: Onikuma K20 - https://www.amazon.com/Onikuma-Surround-Headphones-PC-Lightweight-Earmuffs/dp/B087NW1P78
And my biggest problem here, is Surround 7.1
The Onikuma K20 has virtual 7.1, but the others don't. And I am in doubt about that, how much is it important in your opinion?
p.s: I'm not a professional gamer, and I need it for online meetings, music and stuff like that.
https://linustechtips.com/topic/1254498-help-for-buy-headset/
Sadly I don't think I can help you here. Too low of a budget.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1254498-help-for-buy-headset/#findComment-14088432
Also to clarify. These low budget gaming headset wont make any difference of which one you choose. They are all gonna sound pretty bad anyways. But if I needed to chose one I would take these https://www.havit.hk/products/h2026d-gaming-headset/
Also forget virtual surround. It wont make any difference at all at this price. You can get software to do it better instead.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1254498-help-for-buy-headset/#findComment-14088446
@amirsomeone I would suggest you buy this one, Mpow are pretty good when it comes to ultra low budget audio and I've seen quite a lot of recommendations for this.
https://www.amazon.com/dp/B07WG1FHL2/ref=twister_B088PHRK8W?_encoding=UTF8&th=1
For video calls and meetings you won't notice 7.1 at all. Probably not for music either.
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
https://linustechtips.com/topic/1254498-help-for-buy-headset/#findComment-14088470
