Budget (including currency): 35000 php (philippine peso)
Country: the philippines
Games, programs or workloads that it will be used for: something that can handle ms teams + 15-20 chrome tabs + powerpoint + spotify simultaneously without crashing. maybe also light gaming, (right now, i only really wanna play left4dead but i also wanna try other games in the future). i am also planning on starting a youtube channel next yr, so maybe light to moderate video editing will also be a consideration.
Other details i plan on buying everything by the end of the year because of budget constraints. also because of budget constraints, i'll settle for a gtx1030 for now and will upgrade to a 2060 super some time next yr. i dont really care much for peripherals since im not a gamer (yet), but i do want a 24 - 27 inch monitor. 60hz is enough for me too. i listed the parts im planning to buy below. i believe ive watched enough ltt pc builds to know the basics, but would love to hear from experienced pc builders if the parts i selected are compatible and will be useful for the workload i specified above.
cpu: ryzen 5 2600
motherboard: gigabyte b450 aorus elite (also, vrm is a consideration of the longevity of a system right? i want this pc to last for at least 5 yrs, and i tried reading the motherboard vrm tier list but i dont understand what im looking at. so does this motherboard have good vrm? will it last for 5 yrs)
psu: evga gold 600w
ram: ripjaws v 16gb 3200 2x8gb
boot drive: kingstone a2000 500gb m.2
hdd: seagate 2tb 3.5"
case: any mid tower with bottom psu enclosure
gpu: gtx 1030
thanks berry match for your time ❤️
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/
not good vrm.
go for a asrock pro4 instead, it should be cheaper and slightly better.
otherwise, it sounds like a good plan.
for light gaming, I wouldn't go down the 1030 + 2060 super plan you have. i would just buy a used rx570 now, which will be more than enough for a 60/75hz monitor.
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/#findComment-14087788
3 minutes ago, Tan3l6 said:
Instead why not 3400G? Graphics performance is very similar.
do you mean the graphics performance of 3400g is similar to 2600 + gtx1030? or just the 2600?
i considered the 3400g coz of the integrated graphics. as a said, my budget is tight, and i wouldnt need a gpu for 3400g, but i really want the 6 cores of the 2600.
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/#findComment-14087794
The performance of 3400G is very similar to 2600 plus 1030. The integrated graphics are very good for them being integrated. Vega 11.
Pax vobiscum
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/#findComment-14087800
The GT 1030 is far too expensive for its own good. If you can't get a used GTX 750 TI (which actually performs better in games, and you don't have to worry about accidentally getting a DDR4 version) then I suggest a ryzen cpu with integrated graphics.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/#findComment-14087808
7 minutes ago, boggy77 said:
not good vrm.
there isnt much used rx570 being sold around the philippines. there isnt much used computer parts being sold around the philippines. tho i will try. THAAAANKS
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/#findComment-14087812
there arent much used pc parts being sold around where i live. i only have access to brand new parts, tho i will still try looking. thanks
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/#findComment-14087829
You're spending too much on other parts, your system's going ot be severely held back by that super weak GPU.
Instead, get an i3 9100F with a cheap H310 motherboard, and get a cheap 250/500gb sata SSD instead.
Then you can at least afford a decent GPU like an RX 570 or a GTX 1650
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/#findComment-14090490
3 hours ago, jezsha_makaakit said:
how is the upgradability of these parts? because my original dream plan is to get a 2060 super maybe mid next yr. i want parts that can handle a better gpu when i upgrade.
Next year there'll be better GPUs out. There will probably be better GPUs out by the end of this year.
I recommended that because it seems like you're on a very tight budget, and that prices are really high in the philippines. A 9100F is slower than a 2600x and doesn't have the same upgradeability, but an RX 570 is way faster than a GT 1030. The 9100F+570 combo will be like 2 or 3 times faster than the 2600x + gt 1030 combo.
https://linustechtips.com/topic/1254431-a-noobs-first-pc-build/#findComment-14093155
