*** Thread split from older ***
From
@Paulus88, please don't revive old threads.
Speedfan isn't being supported by most of the motherboards anymore. It hasn't been in ages. Support depends on what controller motherboard uses. So please tell which mobo you have. Its more likely that you need to use another fan controlling software. The options are Argus Monitor and FanControl.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1254366-speedfan-issues/#findComment-14087201
