How to disable CPU fan sensor other than in the BIOS settings
Solved by LogicalDrm,
-> Moved to Laptops and Pre-Built Systems
One drawback on OEM system is that BIOS is usually very locked. Since with intended use, you lease it from service company which would then do service when things break, or you switch it to new when issues start.
Featured Topics
Spencer The Mid ·
Posted in Hobby Electronics0 -
Eurimeee ·
Posted in Troubleshooting1 -
2
