Budget (including currency): 800 - 900 USD
Country: USA
Games, programs or workloads that it will be used for: Programming, Gaming, Video editing.
Other details
https://pcpartpicker.com/list/kgwzK3
I'm upgrading from an i5-7500, 8GB of RAM, and intergrated graphics. (I'm desperate)
Thanks, and sorry for my blatant stupidity.
https://linustechtips.com/topic/1254207-need-advice/
Just now, Tan3l6 said:
If you are not in a very big hurry - AMD new Zen 3 generation CPUs are probably arriving this month.
That is true although I'm skeptical it'll fit within my tight budget. I could wait a bit and buy one with zen 2 architecture. Thanks for the tip!
https://linustechtips.com/topic/1254207-need-advice/#findComment-14085862
Country: USA
Other details
That's a really low tier PSU for that kind of hardware. I'd reccomend using a little more of the available budget to get a higher quality unit.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1254207-need-advice/#findComment-14085907
Country: USA
Other details
Pretty decent setup. If you want to save some money, you could just get the graphics card and maybe the power supply and wait for ZEN 3 before upgrading the rest. Your current CPU should be plenty fast for a 1660.
https://linustechtips.com/topic/1254207-need-advice/#findComment-14085926
Will do, thanks for the tip. Is this better?
https://pcpartpicker.com/list/ZF8J7X
https://linustechtips.com/topic/1254207-need-advice/#findComment-14086002
Thanks for the tip. That seems like a good idea.
https://linustechtips.com/topic/1254207-need-advice/#findComment-14086017
As far as I see, the EVGA BR 450 is still selected.
https://linustechtips.com/topic/1254207-need-advice/#findComment-14086162
