WHats up guys i have a old hp compaq 6200 and i put a wifi card and 8 gigs of ram also I want to add a graphics card. One problem, the metal pcie connector that gets put in the case is too tall for the cover. If you have any suggestions please reply
go follow @sub68, @King of Memes and @wkdpaul.
https://linustechtips.com/topic/1254047-tech/
Could you be more specific? Maybe provide a photo?
There are two PCIe bracket sizes, low profile and regular. If you have a low profile case, you need a low profile graphics card (very expensive)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1254047-tech/#findComment-14084453
-> Moved to Graphics Cards
First search on Goolge gave enough info on this. For one, I thought it might be too old for PCIe. It wasn't, but CPU might still be too old for GPU upgrade beyond 750Ti being even worth it. For two, it has only low-profile PCIe slots. Meaning that full spec cards just won't fit there.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1254047-tech/#findComment-14085203
