what is causing this problem
Go to solution Solved by zain.king,
14 minutes ago, Acid Panda said:
MSVCP140.dll Missing, VCRUNTIME140.dll Not FOund Fix
Missing .dll files is a common issue with PC video games and apparently, Rocket League is not immune to it. According to players, they are getting the following errors.
Missing CONCRT140.dll
Missing MSVCP140.dll
Missing VCRUNTIME140.dll
This can be easily fixed by uninstalling Microsoft Visual C+++ Redistributables and reinstall them, both x86 and x64 versions. This will fix the errors.
https://respawnfirst.com/rocket-league-fatal-error-fix/#:~:text=MSVCP140.,-dll Missing%2C VCRUNTIME140&text=dll files is a common,are getting the following errors.&text=This can be easily fixed,both x86 and x64 versions.
might work
which version should I download I have 2008 version download the same or 2019
might work
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
might work
Download all versions from Microsoft. You want them all installed in case the maker of the game was sloppy and used outdated stuff.
