I was looking on upgrading my system but am kinda stuck with what to upgrade. I want to be able to run 1440p at 144 fps because of my monitor. I have a 5700XT paired with a i5-9600k(haven't overclocked it). I have a Corsair TX850 power supply and 16gbs of ram, And I have an MSI z 390-a pro. Any suggestions are greatly appreciated. Thanks!
https://linustechtips.com/topic/1253371-help-me-upgrade/
48 minutes ago, drew_atkins said:
Oh okay so what graphics card would you recommend because I'm looking at some 2070 super currently.
depends on the games you intend on running. a 2070s might do fine, might want to check some videos of people running the games/settings you are looking for to get an idea.
edit: just noticed your budget is 600$ or less. why not try for a 3070 at launch?
https://linustechtips.com/topic/1253371-help-me-upgrade/#findComment-14079431
bro i totally forgot about the 3070 i think ill upgrade to that. Thanks for the help
https://linustechtips.com/topic/1253371-help-me-upgrade/#findComment-14079450
