I have an ibuypower prebuilt that I bought from bestbuy. BB980 is the model number. I was thinking about getting another fan and didn't see a recommendation list or tier list for that sort of thing. Is it all pretty much similar when it comes to case fans? A believe it has a fan controller as well.
CPU: Intel i9 9900K | Motherboard: ASRock B365M Phantom Gaming 4 | RAM: 4x8GB 2666MHz HyperX Fury RGB | GPU: ZOTAC GAMING GeForce RTX 3080 AMP Holo | PSU: Corsair RM750x (2018) | Case: ASUS TUF Gaming GT301 | Cooler: Cooler Master Hyper 212 Black Edition | SSD: Samsung 970 Evo 500GB | SSD: PNY XLR8 CS3030 2TB | SSD: Samsung 860 Evo 2TB | HDD: Seagate BerraCuda 8TB | Monitor: GIGABYTE G27QC
https://linustechtips.com/topic/1252701-case-fan-recommendations/
I believe most fans are similar, im a newb tho.
Any fan should do just look for one with decent RPM a good bearing and low noise level.
Thats basically all i have been doing lmao and all the fans i have used have been perfect.
Roses are red
the sky is blue,
So is your monitor, Your PC ran into a problem. We're just collecting some error info, and then we'll restart for you : (
most case fans are quite similar, there are some tiers but it's more for air pressure (when using water cooling or CPU heatsink) and noise
top tier $$$:
Noctua - anything from them is gold standard industrial built and will last for decades of builds even when in heavy dust and restricted
BeQuiet  - super silent, basically as quiet as you can get a fan while still pushing air
Mid Tier $$ or RGB $$$$$:
Corsair AF lines - great airflow but seem to be more interested in RGB than performance and you pay a premium for the brand
Fractal Design - were the top tier a few years ago at the dawn of watercooling and just stagnated compared to Noctua and BeQuiet
literally everything else falls below these when it comes to performance and longevity. There will be outliers with great airflow and silence but come from cheap manufacturing processes
DIYPC fans look great, are very inexpensive, push a great amount of air at low noise and will probably run well but not a ton of faith when dust starts to build up in the bearings will they truck on through or just stop one day.
The best gaming PC is the PC you like to game on, how you like to game on it
Noctuas are great fans. I have lots of them. The redux line from Noctua is great as a cheaper option. You just don't get all of the extras that come with the full price fans. Cable extension, splitter, low noise adapter, different mounting hardware and the rubber corners for the fans. Still great fans though.
The Arctic P12 and P14 fans have great reviews too. They are much cheaper as well.
I can't help with RGB fans, but expect to pay at least $40 a fan for anything decent.
