Hello all,
I am looking to do my first water cooling build.  I am doing two radiators, not sure on the size yet.  I am going to cool the graphics card and the CPU.
These are the cases I am considering.
Obsidian 900d
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139019
Phanteks
http://www.newegg.com/Product/Product.aspx?Item=N82E16811854001
Cooler Master Cosmos 2
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119252
I am leaning towards the Obsidian and the Phanteks.  Any other suggestions or recommendations on cases?  I also have a modular power supply and I think some of the leads may not be long enough.  So I may look into getting a new power supply.
Thanks
https://linustechtips.com/topic/125249-case-for-water-cooling/
Put it this way, it is very hard to fill a 900D, so you have plenty of expansion.
But I prefer the 750/800D.
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/125249-case-for-water-cooling/#findComment-1665326
Hell nah! Not 800D :D
750D for sure...
Go with the 750D
900D build quality is meh, youll never be able to fill it
Phantkek solid case and 2nd option
Cosmos 2 isn't made for watercooling and has a terrible internal layout.
^Yes, I'm comfortably water cooling a CPU and 2 GPUs in a 750D, you would really only need a 900D for like quad SLI water cooling.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/125249-case-for-water-cooling/#findComment-1665334
Enthoo Primo or a 750D. They would be the best, as said before the 900D is such an overkill.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/125249-case-for-water-cooling/#findComment-1665452
What radiator setup do you have? A 360mm radiator in the top and a 240mm radiator in the bottom? Are you getting decent temperatures with that?
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/125249-case-for-water-cooling/#findComment-1665487
Yes, I have a a 360 on top and a 240 in the front. All the fans in the case are on the silent profile from the bios and I get great temps! GPUs never go above 50c and CPU stays in the 60s (running at 1.4v).
https://linustechtips.com/topic/125249-case-for-water-cooling/#findComment-1665578
So the 900d is not as good in terms of built quality and is WAY too big from what I am reading.  I am a bit weary about getting something from NZXT.  I had a bad experience with one of their cases a while back although someone said they have done a lot better recently.
https://linustechtips.com/topic/125249-case-for-water-cooling/#findComment-1669716
