i have an alarm on my computer that goes off at 7am every day.
sometimes i forget to turn up my volume, or leave my bluetooth headphones on (those both happened).
is there a way to make task scheduler or some other application turn off bluetooth and set my volume to 100% at 6:59 am?
some chill gamer
setup:
core i7 9700f
16gb 2666mhz ram (dual channel)
512gb sandisk sata boot ssd i salvaged from my broken laptop (lenovo doesn't seem to have great quality ideapad laptops)
480gb sata ssd that came with my system
2tb hdd
msi geforce rtx 2060 super
asrock b365m ib-r mobo
logitech g513 rgb keyboard
logitech m720 triathlon wireless mouse
logitech g935 wireless rgb headset
fifine k669b usb mic
some old samsung 1080p60hz monitor (upgrading it soon)
some cheap "rgb" mousepad i got for christmas
and the most important part, real rgb inside the case
https://linustechtips.com/topic/1252471-scheduled-volume-changing/
Bluetooth control will vary a lot, depending on drivers and software used. Volume can be done with this command line app: https://rlatour.com/setvol/
There is an old powershell script here that might work? https://superuser.com/questions/1168551/turn-on-off-bluetooth-radio-adapter-from-cmd-powershell-in-windows-10
