Hey guys! Last year I purchased a K90 keyboard and I was having a couple problems with it(dead LEDs). I returned it one time and got another defective product in return(bent Keyboard). I returned the keyboard around last May and I got a K95 in return(Thanks for that Corsair!). Now after 10 months a LED on the K95 has died.
My question is: What is the lifetime of the LEDs on these keyboards? Is there any way to replace them myself?
If I spend over $100 on a keyboard I expect it to be pretty flawless, but if I am going to have the same problem again I don't know if it makes sense to RMA the keyboard.
I bought the original K90 at the start of last year, so I am still under warranty.
Other than the LEDs, the keyboard has been great, but I am still kinda bummed that a keyboard this expensive can't even last a year.
What has you guy's experience with the Corsair keyboards? Are they prone to failure?
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/125207-corsair-k95-led-problem/
I had my K90 for over two years. It had worked perfectly and one day decided to have the volume function die.
Contacted Corsair and had no problems replacing the keyboard.
Love Corsair for that.
I recommend you try contacting Corsair again and explaining the situation, they will probably let you RMA it.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/125207-corsair-k95-led-problem/#findComment-1664809
I use a K70 and the first one I got, the LED started burning out within 6 months. Corsair was kind enough to RMA it. It seems like a common situation with their newer keyboards. Their LEDs don't seem to last for too long.
Now I just keep it off unless I really want to shake things up and live on the edge, then I turn them on for a couple hours.
CPU Intel Core i7-4790K Motherboard ASUS Saberthooth Z97 Mark1 RAM Corsair Dominator Platinum 16GB @ 2133MHZ GPU 2 X MSI GeForce GTX GTX 980TI GAMING 6G SLI Case Phantex Enthoo Evolv ATX Storage Samsung 840 Pro Series 256GB / Western Digital Caviar Black 2TB PSU Corsair RM1000i Display Asus 4K PB287Q Cooling Noctua NF-A14 FLX & NF-F12 PWM /Thermaltake Water 3.0 Ultimate 360mm Keyboard Corsair K70 Mouse ROCCAT Kone XTD Sound Card Asus Xonar STX
https://linustechtips.com/topic/125207-corsair-k95-led-problem/#findComment-1664813
I have a k70 and it is flawless. I would just rma it.
https://linustechtips.com/topic/125207-corsair-k95-led-problem/#findComment-1664871
i have a k70 and i have the same problem with the LEDs. i have had my keyboard for almost 6 months and a some of the lights died a few weeks ago, i havent done the RMA yet but i think i will soon also i have read of a few other people on LTT with the same problem with their k70's. Corsair has a problem
https://linustechtips.com/topic/125207-corsair-k95-led-problem/#findComment-1664927
Darn it, I guess I'll try to RMA it again for the third time. I just hate having to wait so long to get it back. I can't stand using a membrane keyboard.
They are really good with their RMAs so I have to give them props for that.
https://linustechtips.com/topic/125207-corsair-k95-led-problem/#findComment-1664970
good to know they are good with RMAs so i wont have to worry when i finally get around to it
https://linustechtips.com/topic/125207-corsair-k95-led-problem/#findComment-1664978
I wouldn't wanna open and replace the LED's by myself if  I were you. Let Corsair RMA it. Their RMA process is pretty fast
CPU: Intel Core i5-4670k Mobo: MSI Z97 Gaming 3 RAM: Crucial Ballistix Tactical Tracer 8GB 1866 Video Card: MSI GTX 970 GAMING 4G SSDSamsung 840 Evo 250GB HDD: WD 1TB + 500GB Caviar Blue
PSU: EVGA SuperNOVA 750W G2 Case: Gigabyte GZ-G1 Mouse: Corsair M65 RGB Keyboard: Corsair K70 MX Brown MousePad: Corsair MM200
Steam/Origin/Uplay: renz62
https://linustechtips.com/topic/125207-corsair-k95-led-problem/#findComment-1665082
