Current pc -https://uk.pcpartpicker.com/list/PY3Pyk Im from the uk and i play 240hz fortnite however fps isnt as good as it used to be i was wondering what would be best to upgrade i have game boost enabled on the 3600 btw also water cooled but dont think i put that in just realized but what would i need to spend to get a solid fps boost
https://linustechtips.com/topic/1251380-i-need-help-upgrading/
Threads merged and moved to New Builds & Planning. Please post in the correct forum and don't repost the same post.
https://linustechtips.com/topic/1251380-i-need-help-upgrading/#findComment-14060616
Then turn down the graphical settings to increase FPS for the time being. For the rest of the build, I would start with upgrading the GPU and PSU to a more powerful GPU, such as Nvidia's RTX 30xx series or AMD's 6000 Series by waiting a couple of months for prices to settle due to demand. For the PSU, I would go with at least a 850W from our PSU Tier List from at least a Tier B or higher (Tier A).
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1251380-i-need-help-upgrading/#findComment-14060638
i have settings on lowest but ok thanks
https://linustechtips.com/topic/1251380-i-need-help-upgrading/#findComment-14060980
