So i have mounted a virtual dvd on windows 10, like usual, but after ejecting it, the dvd drive didn't disapear and i cannot delete the dvd i had mounted before because i get an error (see image).
My laptop doesn't have a diskdrive, but it still shows up in "my computer" and when i double click it, it asks for a disk.
No way to remove it either. When i try to remove the dvd in question, windows tells me it is open in another program.
I went into the disk management, but i cannot do anything with the partitions, when i right-click, it only says "help" and redirects me to a useless mircosoft site.
I want to remove this without resorting to a clean install to windows 10 if possible.
There are no restore points to go back to and googling this issue didn't yield any results.
Does anyone know how i can fix this?
https://linustechtips.com/topic/1251303-problems-removing-virtual-diskdrive/
Try restarting your computer. It shouldn't remount itself upon the next startup I don't think.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Sorry, forgot to mention, restarting doesn;t help. Shutting down and rebooting either.
Try moving that ISO file to a different location and restart. It shouldn't be able to locate the ISO file and remount after that. Either way, that's not normal behaviour for Windows as it should never try to remount any ISOs or Virtual Hard Disks during startup. I would check to make sure you have the latest updates installed and make sure you have the latest version of Windows 10 installed.
it is "in use" it cannot be deleted or tranfered.
When i go to the properties of the dvd drive and delete it, it is gone, but the dvd file remains in use.
After restarting, the dvd drive is back.
