Im currently in the process of putting together my firsrt rig, i wanted to make sure everything booted ok before i put my graphics cards in and installed the OS. Problem is that my PC starts up, but after a few seconds it cuts right off and repeats the the same thing over and over
My mobo is an ASUS ROG Maximus V Formula, 3770k,
anyone know what to do about this?
https://linustechtips.com/topic/12512-first-build-issue/
I figured out the problem, the 8pin got knocked loose, its all good now
It's a common mistake, I've done whilst the system was on ;P
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/12512-first-build-issue/#findComment-133820
I can only imagine the internal panic this caused haha
It was pretty much: Hay! why is my computer off? *looks inside it* Oh, that's why. *facepalms*
https://linustechtips.com/topic/12512-first-build-issue/#findComment-133834
