Ok so as the title states im in the market for a case seeing as i will be doing my first pc build very soon!!
My original choice was corsairs new 760T but then i was looking at the corsair 750D they are both amazing cases and i like them both....
Somebody was telling me that one of the flaws the 750D is the front grill its not perforated to allow airflow like the 760T...
I really dont know guys i love both cases but i want your help..!
Please help me choose a case..
https://linustechtips.com/topic/125108-need-help-with-picking-a-case-please-help/
Yeah i know that why i like both.. I kind of like the sleekness to the 750D over the 760T but the 760T has a big window and looks to have better airflow.. The 750D looks like to have a better build quality though..
760t has the same interior as the 750d, with upgrades to it. It's basically picking which you like best.
They are both awesome cases, technically and design wise. Choose what you find looks better.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
If I were you i would look at review video's on both cases and based on the features they both have and which one has your interest more get that case
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
If you want a more simplistic look go with the 750D or if you want LEDs and you want that really nice window side panel with the handle go with the 760t, good luck  :)
Christian and Proud of it
Please read the CoC        My Build Log
They are going to be basically the same build quality wise. If you dont like the window and dont care for the retarded usb passthrough problem on the 750d, then get that. If you like the big window, and less quirks, get the 760t.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
In terms of style, they're totally different. Both are great. Get whichever you prefer.
what problems does the 750D have?
|King Of The Lost|
Ill probably be swapping the leds for better fans
Well i really like the side panel with the window and handle, but if you want the really nice look of brushed aluminium i would go with the 750D especially if you do not want to wait for the 760t
Well i have to wait for the 760T regardless because of tax returns
Ok well, if you are going to swap the LEDs with non-LEDs and if you do not care about that side panel i think you should go with 750D
The 750d uses a usb 3 passthrough, which means you need to plug actual usb cables into the back of your motherboard to get the front panel usb 3 to work. 760t doesnt have that issue.
the side window of the 760T is what i really love about it lol!
Well then i would go with the 760T, then and it is always nice to have the option to add LEDs
