Hello, I have a msi gaming trio 2080 super, R5 3600x, b450 max, kdm 775w psu. I just bought the gpu and it never posts. I know the pc works fine with my old gpu. But when I switch it back it stays stuck on vga led. I have a feeling it’s either the psu or the card is faulty but I’m hoping someone can help me out here.
I tried clearing cmos, I use 2 different metal pieces and left them there for at least 30 seconds each with psu switch off.
I test it with my gt 720 and updated my chipset and bios and manually downloaded 2080 driver.
No no extras are plugged in. Only essentials.
I tested each 8pin plug on my psu with a multimeter m and 2 pins didn’t work. I stole power from my sata and molex plugs and soughterd it to route power to gpu.
I have no more ideas
https://linustechtips.com/topic/1251000-b450-max-vga-led-error/
5 minutes ago, aydin_is_here said:
Hello i can help you . You have a 2080 its a good gpu but the cpu isnt storng enough it is maybe bottlenecking . Or You may need to Reset Your Computer
This would have nothing to do with his computer not posting
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
https://linustechtips.com/topic/1251000-b450-max-vga-led-error/#findComment-14057148
