I have a samsung 320gb 7200rpm hdd but when I ran speed test with crystaldisk 6.0 it's speed are as follows
Read speed- 45-50mb/s and in other read speed columns it was even low as 0.9 mb/s
Write speed- 100-110mb/s and in other write speed columns it was about 0.9-1mb/s
Plzz help me how can I fix this or increase speed without data loss or removing os.!?
https://linustechtips.com/topic/1250951-slow-hdd-speed/
It maybe fragmented, you can try defrag.
Check the disk and try to repair any errors.
Depending on the age, it might just failing.
You should prepare a replacement drive, ssd recommended.
https://linustechtips.com/topic/1250951-slow-hdd-speed/#findComment-14056849
Click on the drive drop down and choose the 320 gb hard drive.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1250951-slow-hdd-speed/#findComment-14056850
2 hours ago, sarabjeet24 said:
Bro I have partitioned drive c so i am checking it
Sorry it was just that you wrote that it was a 320Gb and the partition didn't show anything more than 78Gb.
What does CrystalDiskInfo say about the drive?
https://linustechtips.com/topic/1250951-slow-hdd-speed/#findComment-14057355
