What is the difference between
https://pcpartpicker.com/product/hDZzK8/deepcool-gamerstorm-captain-360x-white-644-cfm-liquid-cpu-cooler-captain-360x-white and
https://pcpartpicker.com/product/hymxFT/deepcool-captain-360ex-white-rgb-2296-cfm-liquid-cpu-cooler-captain-360ex-white-rgb
One is a bit more expensive, so I mean is one just like the updated model?
Also, I think I wanna get the cheaper one as I'm on a bit of a budget. I'm also considering https://pcpartpicker.com/product/smDkcf/arctic-liquid-freezer-ii-280-728-cfm-liquid-cpu-cooler-acfre00066a which is a 280mm radiator, but it is considerably thicker than the 360 models so I'm wondering what will provide more cooling? If they are all about the same I think I would get the deepcool captain one, as it's the cheapest. (On AM4 which I think all of them come with).
https://linustechtips.com/topic/1250922-difference-between-2-coolers/
Best as I can tell from searching, the 360X is the newer model with 280W TDP, and support for Threadripper chips. The 360EX is 140W TDP and is AM4 on the AMD side.
What CPU are you wanting to cool? If you're on a budget, you might be better off with an air cooler.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
2 hours ago, zinton said:
One is definitely cooler
Ba dum tss.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
