upgrading help
Go to solution Solved by BlueChinchillaEatingDorito,
If you can find an additional 8GB of DDR3 on the cheap, you should be able to squeeze a bit more life out of that i7. It's not going to be amazing, but it's not going to be terrible either. But I would seriously look into upgrading that PSU. You'll still be able to use it in future builds so it's not a bad investment now.
Looks like your non even 80+ rated PSU made it on our Tier E list. Tier E meaning "Potentially dangerous in multiple scenarios".
So I currently have a decent enough pc, it runs most games fine but a couple parts could use upgrades.
Current specs are:
i7-4790
8gb ddr3 @ 1600Mhz
gtx 1060 3gb
some pretty bad chieftec 650W psu that isn't 80+
I've been looking into the new 30 series gpus and they seem appealing since they are priced better than last gen and I could use the higher settings at a better framerate.
I have also had issues with stuttering but that could've been a power delivery or RAM issue.
My question now is that is it worth upgrading my current pc to 16gb ram and a new psu or should I just look into building a new pc? Because I do stream sometimes I feel as though my cpu is also holding me back a bit but that could also partly be attributed to the lack of RAM.
tl;dr should I get new pc or upgrade current setup
https://linustechtips.com/topic/1249710-upgrading-help/
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1249710-upgrading-help/#findComment-14045318
I currently have dual channel 8 gb and I doubt my mobo supports quad channel so I'd have to get a new 16gb kit. Is it still worth upgrading in that case? As for the psu I found a phanteks revolt 1000W 80+gold for 179€so I'll be getting that asap.
https://linustechtips.com/topic/1249710-upgrading-help/#findComment-14045433
It really depends on the price of that DDR3 kit. I personally haven't noticed a difference between single channel and dual channel operation in games. I can't say much about streaming since I don't stream myself.
https://linustechtips.com/topic/1249710-upgrading-help/#findComment-14045436
