Hi
I have had a problem with my computer, as in it has shut itself down randomly. I found out that 12V rail is getting only 9V-10.5V, I removed 2 of my RAM sticks and now it gets over 11V reliably.
I have Gsill RipjawsX as my RAM, 2 8GB kits(2x4GB) I believe that the problem is my 2-year-old PSU, and I could get a new one in a few days time, but is the problem my RAM, MOBO or PSU?
Rodakin: AKA: Hitman, Occupation: Master assassin        ....or just a student... whatevs...
https://linustechtips.com/topic/124951-ram-causing-stabilization-problems/
Hi
so you have 16gbs total, and you bought two seperate 8gb kits?
If you did, i think its a timing issue with the ram. When you buy ram next, try to get the amount you want all in the same kit because they have a better chance of working together. While ram does work together in different kits, sometimes they have an issue and just dont like to work together.
Edited by Hotnuggets
I was afraid this could be the problem... However it did work when I got the RAM last Christmas... only quite recently has it had random shutdowns. Do you think a new PSU could fix the problem?
a new psu wont fix the timing issue.
You would have to get new Ram, or take one of the kits out and then just use 8gbs. You could do a memory test and test each stick to make sure they're all working properly although i do believe it is a timing issue.
  • 3 weeks later...
Hello! I just got a new PSU, a Corsair RM850, using only one kit, I'm getting nearly sufficient voltage, from 9.984 V to 10.084 V. What can I do? Do I need to change the PSU AGAIN?
