Need help cooling computer
Solved by LogicalDrm,
@Phage, couple things. Add two fans to intake on top. They will help GPU. Now I assume that you are on air with CPU. Make your CPU cooler blow air towards PSU and have rear fan intake as well. So rear and bottom fans will intake air for CPU and two top fans will intake for GPU. I'm not experienced with small cases so I can't say if they really need exhaust fans.
