I kept getting CPU FAN ERROR whenever I boot up my pc so after researching I found out that you can just ignore the CPU FAN MONITORING in the bios. But my problem now is, my cpu fan does not spin anymore. Should my cpu fan still spin if put the CPU FAN MONITORING to IGNORE?
My cooler has two fans and only the back one is spinning. The front one just spins for a second when I boot up my pc
https://linustechtips.com/topic/1248779-cpu-fan-error/
You got the CPU FAN ERROR because it was not spinning.
Replace the fan with a working one and the ERROR (about the fan not spinning) will most likely go away.
Or just change the plugs for the fans. Plugin the front one in the socket the back one was connected to and vice versa.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1248779-cpu-fan-error/#findComment-14037738
