Nee help with choosing CPU
Go to solution Solved by Gorou92,
yeah z390 will support a g5400
Hi, so basically I need a CPU to check if my Asus Z390-H is faulty (The CPU corner is bent but works only when GPU is not installed, technician said it may be the motherboard as well).
I though buying a secondhand G5400 would be a good choice since it's the same socket and should be supported.
so my question is, will it work ?
https://linustechtips.com/topic/1248691-nee-help-with-choosing-cpu/
