Hello welcome to the forums! It sounds to me like your SSD died. It can happen from time to time, likely a defective unit from the factory if it died that quickly. I would contact lenovo or the retailer you bought the computer from for a return/replacement. Or just order a new drive online and put it in yourself. You can reset your bios to default settings and reset the CMOS if you want to try a couple things to make sure but typically when the drive doesn't even show up in bios it's toast.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1247977-plsssss-need-help/#findComment-14030837
