Current specs
Amd Radeon rx570
Amd ryzen 3 2300x
Msi a320m pro-m2 v2 motherboard
Corsair vengeance 32gb 3.2ghz ram
Hyper 212 cpu cooler
Wd blue 1tb hdd
Lexar 256gb ssd
Evga 600 gd 80 plus gold power supply
I'm new to pc building and got this as a gift, and I am wondering what I should be upgrading to get this thing to a decent level. Any advise would be greatly appreciated.
https://linustechtips.com/topic/1246541-need-help-with-upgrading/
This. A Cheep b550 will be much higher quality.
2 minutes ago, Joeblue said:
Amd Radeon rx570
Then this. A used rtx 20xx cats after the 3070 comes out in October will be a huge upgrade.
3 minutes ago, Joeblue said:
Amd ryzen 3 2300x
Then this. A r5 3600 or a r5 4600 (when it comes out) will be a big improvement.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
all depends on what you want it to do. what will the pc be used for? work horse? streaming? gaming? what resolution and refresh rate do you want?
39 minutes ago, Joeblue said:
Current specs
Amd Radeon rx570
Amd ryzen 3 2300x
Wd blue 1tb hdd
Lexar 256gb ssd
How much are you able to spend now, and how much are you able to spend later on?
Depending on what you want to do and what your budget is.  Are you a gamer, just read the news, something from work maybe?  What you want to do will depend on things such as these listed here so be sure you know what your intended end result should be.
Good luck.
When I hear somebody sigh, "Life is hard," I am always tempted to ask, "Compared to what?"   Sydney J. Harris
