What sound card do I have?+-
OneManCruel
Hello guys, I've been trying to find out what kind of sound card I've got for the last couple of minutes, downloaded 2 different programs that scans your computer components and all I've found in the audio category was:
NVIDIA High Definition Audio
VIA High Definition Audio
NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Sennheiser 3D G4ME1
I can't find anywhere that Nvidia has made any audio cards so I guess I'm missing something...
Thanks!
The GPU outputs audio through HDMI, as most do.
You have an audio chipset from VIA.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
Nvidia HD audio is the audio outputed from the HDMI in your GPU so don't worry about it. But VIA I think is a competitor to Realtek for onboard audio so I imagine it is your motherboard sound.
"If you do not take your failures seriously you will continue to fail"
was the comic sans necessary?
all Nvidia's chips do are send the digital audio signal to a receiver to be converted to analog.
