2 minutes ago, SgtIronWolf said:
its rated for 1200 watts so its running my new hardware fine.
Could you send an image of it and please quote me next time
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1245195-old-power-supply/#findComment-14008231
It'll all be for nothing if it isn't rated well on the efficiency certification. What's it rated at?
My Build (5800X3D, RTX 3070)
disclaimer: i probably don't know what I'm talking about but I try to give the best advice I can
https://linustechtips.com/topic/1245195-old-power-supply/#findComment-14008239
BFGs (only?) 1200w unit is rated as 80+ standard when it was certified 11 and a half years ago.
The efficiency doesn't really matter that much, but being more than a decade old is a concern.
https://linustechtips.com/topic/1245195-old-power-supply/#findComment-14008285
