Hi, i have a gigabyte gtx 1650 super and i think its oc edition...
so the problem is today i let MSI Afterburner OC scanner scan for a good overclock...
And now that my card is overclocked its gets hotter, like expected.
Can someone help me make a good custom fan curve?image.png.a35228262055293189ba028099acf3fc.png
https://linustechtips.com/topic/1244607-hello-i-need-some-help/
Higher Fan RPM = More Noise, and everyone has a different tolerence for PC noise. On top of this, you haven't given us specific temps so there's little that we can do to help you.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1244607-hello-i-need-some-help/#findComment-14003015
4 minutes ago, The Paradox-_- said:
My pc isn't that quiet so i can handle it
but like for example Fortnite for some reason was at epic setting was i think at 72 celcius
Well if you can tolerate the fan noise as is, and if your GPU temp is sitting at 72C (which is not high), your fan curve probably doesn't need to be modified.
https://linustechtips.com/topic/1244607-hello-i-need-some-help/#findComment-14003039
