i need help with a dual monitor setup (for streaming)
baconman699
i have two different monitors that i want to have split feed on i'm a streamer but i want to have one monitor for my chat and one for my games but it wont work i have a monitor connected to my GPU and one to my motherboard DVI to GPU & VGA to motherboard but the VGA wont work! i have a HP Compaq pro 3000 and a AMD radeon R5 240 i use windows 10 for this setup and its not detecting the second monitor....
the motherboard will not do displays when there is a gpu
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, Akaso EK7000pro
Dead cameras: Nikion s4000, Canon XTi
Pc's
Dell optiplex 5050 (main) - i5-6500- 20GB ram -500gb samsung 970 evo  500gb WD blue HDD - dvd r/w
HP compaq 8300 prebuilt - Intel i5-3470 - 8GB ram - 500GB HDD - bluray drive
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 4GB ram - 1TB HDD - dual DVD r/w
main laptop acer e5 15 - Intel i3 7th gen - 16GB ram - 1TB HDD - dvd drive
school laptop lenovo 300e chromebook 2nd gen - Intel celeron - 4GB ram - 32GB SSD
audio mac- 2017 apple macbook air A1466 EMC 3178
Any questions? pm me.
#Muricaparrotgang
then what do i do?
i have no options here....my GPU has two ports displayport and DVI but my two monitors only have VGA & DVI....
i kinda have no idea what to do....
1 minute ago, baconman699 said:
then what do i do?
You should be able to get an adapter from DVI to VGA or DP to VGA, you will need an active adapter
nope my motherboard has VGA my GPU has DVI and displayport i have to connect one monitor to my motherboard and one to my GPU but the one on my motherboard wont connect
What CPU do you have?
If it have iGPU, then you can re-enable it in bios and the ports on the motherboard will be available
-sigh- feeling like I'm being too negative lately
Then get the adapter? If your GPU has DVI and DP then get the adapter from the available port to the connector your monitor uses.
Intel i7 2600 socket lga1155
Enable iGPU in the bios
It's disabled by default when it detects a dGPU
what do i do my bios is a pain in the ass to get into i have the worst PC ever! HP compaq pro 3000 sucks....
Every bios is different so you'll have to poke around
You could snap photo and upload here on your phone if you're unsure
update its a HP Compaq pro 6200 but that does not help me, anyway i tried to get into the bios and i did it! got FUCKING NOWHERE integrated graphics, changing the priority on VGA, nothing fuck this PC for everything its worth!!! also i made it even worse now i cant connect to my old monitor  so i'm stuck at 1440-900 on this shitty Samsung monitor i have no clue what to do still and im probably gonna take this thing to A+ to try and figure this out
i would add that not every company makes the best bios
and if you do mess something up, just reset the bios (should be an option in there on the save and exit page, or use jumper)
HP confirms that the Intel-based HP Compaq 6200 Pro Series desktop systems contain DDR3 volatile memory (memory amount depends on the customer configuration). In addition, the motherboard, in the condition originally shipped (without subsequent modification or the addition or installation of any applications, features, or functionality), contains the following nonvolatile memory: Real Time Clock battery backed-up configuration memory (256 Bytes), DIMM Serial Presence Detect (SPD) configuration data (256 Bytes per module, 128 Bytes programmable), Serial Peripheral Interface (SPI) ROM for System BIOS (8M Bytes) and Super I/O’s: masked keyboard ROM (overall 2K Bytes). In addition, these units contain a Trusted Platform Module (TPM) that contains 16K Bytes of nonvolatile memory for consumer data. The volatile memory will not hold any consumer data once power has been removed for 30 seconds or longer.
no clue what this means or anything but if you can help me out it would be appreciated!!!!             https://support.hp.com/us-en/document/c03503774
Can you snap a photo of the bios?
apito setup utility 2.10.1208
jo1 v2.25
that all the info i could get from the system information
jo1 v2.25
do you have a phone you can snap a photo with? and post it here?
I! do not....
5 minutes ago, baconman699 said:
I! do not....
then it would be quite hard for me to guide you
perhaps sending an email to HP asking how to enable the iGPU would yield better results
